2 Pages<12
metropical
#11 Posted : Sunday, November 25, 2018 3:56:58 PM(UTC)
metropical
thanks for the tech sheet.
I'm going to install the evap motor as it's still a little grindy and take a snap then.
I don't get site updates neither. ah well.
metropical
#12 Posted : Tuesday, December 4, 2018 9:37:59 AM(UTC)
metropical
Got a evap motor. Opened the freezer back panel up and found this chunk of ice.
Turned fridge back on and observed evap motor which seemed to not be having any issues.
It is the bi-metl defrost sensor(?)caked in ice.
In any case, I defrosted the chunk of ice and put the cover back in place with 4 screws.
Turned the unit back on. I'll check back in a couple hours.
UserPostedImage
UserPostedImage
Edited by user Tuesday, December 4, 2018 12:21:45 PM(UTC)  | Reason: Not specified
metropical
#13 Posted : Wednesday, December 5, 2018 6:04:37 AM(UTC)
metropical
16 hours later, no change. Time to call Thermador. Darn the Luck ! ! !
UserPostedImage]Dec 5 - 16 hours later[/img]
UserPostedImage]Dec 5 - 16 hrs later[/img]
ohm
#14 Posted : Wednesday, December 5, 2018 6:08:57 AM(UTC)
ohm
That looks like a sealed system problem.Meaning compressor not pumping right or freon leak or capillary restriction.
The compressor would be running 100 percent of the time if any of these scenarios! You maybe at the end game with this!
ohm
#15 Posted : Wednesday, December 5, 2018 6:14:16 AM(UTC)
ohm
Yeah just saw your last post and 16 hours later! Looks bad for you.
metropical
#16 Posted : Wednesday, December 5, 2018 2:15:54 PM(UTC)
metropical
yup. new drain pan heat element (most likely) and evaporator.
Recharged until parts come in. Other bits test well. Compressor, etc.
2 Pages<12
