Good evening.
The unit powers up. All the functions on the control panel appear set when selected. It is not throwing any error codes.
I have already disassembled once. Continuity has been checked on the thermal fuses and thermostat. There appears to be a total of 4. Thermal fuse part# 6931EL3003D was bad and has been replaced. The resistance on the heating element was checked. I observed 20 AB, 20 BC and 50 on AC if I recall correctly. According to LG that 50 should be below 10. I checked the strings and they looked good.
Any advice would be appreciated.
Thank you.
Just tested the continuity on the door switch. It appears to be dead.
I don't see it - so I have to ask , 240 volts from black to red, L1 and L2 ? Belt switch made up? Is the problem it will not start to spin ??
Originally Posted by: RobertSD  I don't see it - so I have to ask , 240 volts from black to red, L1 and L2 ? Belt switch made up? Is the problem it will not start to spin ?? I did not do a voltage test on the heating element. Just a continuity test. As stated earlier I have already found a bad door switch and thermal fuse. I have not tested the belt switch as of yet. The unit does nothing when I start the cycle. The LED does say drying. Edited by user Sunday, November 11, 2018 5:36:40 AM(UTC)
| Reason: Not specified
Replaced the switch. The one on the door was def dead. I checked the continuity on the new one. Both sides are alive. Where as on the old one, one side was dead. Still nothing. However when I push the start button I do hear something. It says drying. So it could be strings heating up. I noticed the check filter indicator is on. Everything is clean there. Advice? Ideas? I have not checked the drum switch as of yet. Edited by user Friday, November 16, 2018 10:21:57 AM(UTC)
Problem solved.
The vast amount of assistance provided has been greatly appreciated.
#Sarcasm.
