Long story short - my wife decided I should try to find out why our dishwasher isn't performing like it used to. I managed to disassemble as far as getting some kind of fine filter housing exposing a little stainless propeller looking think. But there was a bit of standing water with 2 little plastic balls floating. After doing some reading I know they are "check balls", but where are they supposed to go? Thanks
Or perhaps where I could access a parts explosion picture?
Originally Posted by: ohm  Thanks for that. I actually found a different video that helped me out - but now have another problem. I got everything back together, test ran it and seemed good. But then I found a very thin plastic washer on the floor where I had placed all the parts. Looking at a explosion drawing I found it wasn't there. Any idea where it goes , or should I start tearing it back apart trying to figure out where it should go?
That's it. Got it back in it's place. Thanks so much for your assistance!!
Originally Posted by: ohm  Like in this screen shot.It's called the nozzle bearing! +1
