candlepower
#1 Posted : Saturday, May 23, 2009 3:33:55 PM(UTC)
candlepower
Our A/C condenser/compressor unit was replaced recently. The old unit was 10 seer, the new unit is 13 seer. A home inspector tells us that the old breaker 35amp, needs to be replaced with smaller? one at 30amp to match the new compressor. Is that necessary? Safe?
#2 Posted : Saturday, May 23, 2009 7:10:58 PM(UTC)
The size of needed breakers should be written on the name plate of the unit and in the installation manual.
candlepower
#3 Posted : Tuesday, May 26, 2009 8:16:53 AM(UTC)
candlepower
Thank you for your quick reply!
#4 Posted : Tuesday, May 26, 2009 8:13:24 PM(UTC)
You are welcome.
icehouse
#5 Posted : Sunday, May 31, 2009 5:39:06 PM(UTC)
icehouse
Breaker should correspond to 125% of the total amperage of the machine. :)
Guest (5)
