AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
LG Dryer won't turn on, but light on inside drum.
hello,
I've got an LG electric dryer, only a few years old, and midway through a cycle it just stopped. I went to restart it but it would not power on, despite the fact the light was on inside the dryer. I flipped the breaker on and off, still nothing.
I checked the vent, which is rigid, thinking it might be clogged and had tripped things, but it was quite clear.
I did some searching and found suggestions: - pressing reset button inside the machine - via the dryer vent hole - but my version is electric and doesn't have this switch it seems? - I tried turning off the machine, holding down power button for 5 seconds then turning on again. - some people suggest that it could be one of the thermal fuses - and I haven't checked the continuity on these yet since I need to borrow a multimeter - but before heading down this path, which seems to involve dismantling the entire machine....? i wanted to be sure that the symptoms point to this, and not to something like a faulty control panel?
What might my next steps be?
Thanks in advance for the wisdom,
Paul
It sounds like you lost one leg of the 240 volts. Lights will come on with only 120 volts.
ok, interesting - so does this mean install a new breaker then? or maybe the connection at the plug is flaky?
Im no electrician but i replaced a old dryer one time and the new one did the same thing !! Found a poor connection at the house side of the plug. Kill the breaker and remove the cover on the outlet. The screw on mine had back out, i guess from vibration, and it was only getting half the voltage required.
took the cover off, checked all connections, rechecked voltage on both sides of the plug and both read 120.
checked the continuity on the thermal fuses deep inside the machine too - which seem to check out
so, any other thoughts of what i could check next?
Dryer Repair
