Glad it helped.
Received nothing but defective Timer switches from the vendor (Whirlpool), so bought a new dryer.
Problems solved. ;-)
Thank you so much for the article How to Check Continuity with a Ohmmeter. I have had a hard time finding a book that is able to guide a beginner on the proper use of an Ohmmeter, and appreciate the information.
Greetings... Wirlpool #ler4634eq2... Everthing runs - except there is no heat... I replaced the heating element - did not fix the problem.... Pruchased a multi-meter today so I don't waste any more money on replacing parts I do not need... Problem is what to set the meter on...everything I read says rx1...the meter I have does not have a Rx1...under the OHM's dail it has X1k and X10...Help???...which do I use??.. And, what parts should I check??..thermostat, thermal cut off, thermal fuse??...am I on the right track here.. Thanks so much for your help...
Originally Posted by: Gene Hi thiendia, The problem with your dryer caused by a bad gas valve coils . No doubt about it. - The part number for the coil kit is AP3094251Here are the break down diagrams for the Whirlpool dryer Model SGDS800JQ2Gene. THE gas valve coils when check for continuity do the smaller of the two show open?
hi there Gene the problrm that I have is my electric dryer Whirp is not working I checked the electric panel amd also the belt seems fine My guess is that the motor is shock my drfyer is 5 years old and I do not not how 2 use a ohmmeter or multimmeter ( I have something with these labes DCV< ACV< BATT< MA< OMEGA SIGN < AND TWO SYMBOLS ? so I am really confused how to find out the problem by the way the model is LEQ9598LWO
Yes this was good thanks a lot for the informatin now I just need to find the value for a oven igniter
Originally Posted by: bobobeasley Yes this was good thanks a lot for the informatin now I just need to find the value for a oven igniter Can you be more specific on the problem? What is the complete model number of the oven? Gene.
