Discuss
Electric dryer won't star
 in
Dishwasher Repair
Hi there! I have a whirpool dryer and wont start at all I checked the power and is fine 15
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Electric dryer won't star
  #1 (permalink)
Old 06-24-2009, 01:05 AM
Eduardo 71 Eduardo 71 is offline
Junior Member
Eduardo 71 is on a distinguished road
Unhappy Electric dryer won't star
Brand: Whirlpool   Age: 1 - 5 years
Hi there!
I have a whirpool dryer and wont start at all I checked the power and is fine 15 minutes later y can hear the timer working, but anything else isn't
  #2 (permalink)
Old 06-24-2009, 06:46 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
A Model Number may help others help you.
__________________
  #3 (permalink)
Old 06-24-2009, 02:57 PM
Junior Member
Default Whirpool electric dryer
I wrote yesterday abou t my dryer not working the model is LEQ9508LW0
AND ALSO I LIKE TO KNOW HOW TO USE THE OHMETER
  #4 (permalink)
Old 06-24-2009, 03:03 PM
Junior Member
Default
I have a digital ohmmeter and would like to know where to set te dial if is the DC THE MA OR THE OMEGA SIGN, I cheked the belt and seems fine I don't have a manual and do not know wheres the thermosta, heating element or also how to chek any of these for continuity? THANKS FOR YOUR HELP
  #5 (permalink)
Old 06-24-2009, 04:08 PM
Junior Member
Question
[quote=Eduardo 71;100604] Hi there Denman I have a digital ohmmeter and would like to know where to set te dial if is the DC THE MA OR THE OMEGA SIGN, I cheked the belt and seems fine I don't have a manual and do not know wheres the thermosta, heating element or also how to chek any of these for continuity? The dryer won't star For what I've been reading I think the motor is shock and I think what I have is a mutimmeter
but I am not sure
  #6 (permalink)
Old 06-24-2009, 07:14 PM
Senior Expert
APP Volunteer
Default
Here is your parts breakdown
Replacement parts for WHIRLPOOL LEQ9508LW0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/docs/...%203406661.pdf
Here is a good site with basic dryer repair help
http://www.applianceaid.com/dryers.html
The Omega sign should be ohms/resistance
Since the timer is running the door switch is probably OK.
The most likely culprit would be the THERMAL FUSE (196 degrees) in the motor circuit.It is the one mounted on the blower assembly (Item 7 in "Section 3")
If it is blown check that the blower is clean and OK.
Also clean/check your vent system.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas dryer to electric dryer convertion. Fhabeeow Dryer Repair 1 01-08-2008 08:49 PM
