fil_bagwadia
#1 Posted : Monday, April 9, 2018 5:51:53 PM(UTC)
fil_bagwadia
I have a Whirlpool Duet front loading washer model WFW9400SW that has stopped dispensing fabric softener. I have cleaned the tray but no luck. It has no problem dispensing detergent.
Please help. Thanks
brobriffin
#2 Posted : Monday, April 9, 2018 6:45:35 PM(UTC)
brobriffin
Man
United States
Whirlpool WPW10352973 Dispenser Motor and Switch Assembly - AppliancePartsPros.com
watch the video on this link
it is the switch motor that changes the water flow from detergent to bleach to fabric softener
something tells me this motor (part 10) or the linkage (see parts 7, 8, 9 & 11 on chart) isn't working properly
does it dispense the bleach properly?
brobriffin attached the following image(s):
fil_bagwadia
#3 Posted : Wednesday, April 11, 2018 4:52:00 PM(UTC)
fil_bagwadia
Thank you. We normally do not use bleach but I shall try and see if it dispenses and will let you know. Thanks again.
fil_bagwadia
#4 Posted : Thursday, April 12, 2018 2:43:15 PM(UTC)
fil_bagwadia
Tried bleach and that too does not dispense. Detergent is the only liquid that dispenses.
Is there a way I can verify that its the switch motor that I need? I am reasonably handy.
Appreciate your feed back.
Guest (4)
Brand New Kenmore HE Top load Fabric softener not dispensing (Washer Repair)
by jeffmccracken 6/10/2016 7:46:21 PM(UTC)
Fabric Softener not dispensing (Washer Repair)
by erkflys 7/11/2009 9:43:15 AM(UTC)
