vbrown
#1 Posted : Tuesday, May 26, 2009 9:36:53 AM(UTC)
vbrown
A foodbag with a metal strip flashed and caught fire in the microwave, was able to put it out fast. Microwave cleaned up accept a plastic disc top of the inside of microwave was discolored. Microwave works. Is the microwave safe to use ?
#2 Posted : Tuesday, May 26, 2009 12:24:06 PM(UTC)
If there is no damage to the inner door panel and the cavity panels then it's probably safe to use.
Guest (4)
Microwave Fire (Microwave Repair)
by Roddog 8/18/2013 9:10:16 AM(UTC)
