12 Pages«<101112
challis91
#111 Posted : Sunday, September 28, 2014 4:07:52 PM(UTC)
challis91
Does anyone know what the tolerance is for the coils inside of a drain pump I am wondering if mine isn't too high I know that is a long distance to carry a charge but I got 13 ohms when I tested it. is that within spec or is it a little high it has stopped the drain process once but all O-rings are good and wires test out fine. this is the second drain pump in 4 months.
hamed22
#112 Posted : Friday, March 2, 2018 11:07:19 AM(UTC)
hamed22
Hello
I wanted to know what tool is needed to charge the gas cooler gas
repair
Guest (13)
12 Pages«<101112
