Hello All
I have an electric LG dryer that won't stop tumbling.
Once the drying cycle is complete the heat function stops but the dryer keeps tumbling (cold air blowing).
The machine display is all off as if the cycle is complete.
The only way to stop the tumbling is either open the door or unplug the machine. once the door is closed the tumbling continues.
Besides this the dryer works fine just want stop tumbling at the end of the cycle.
Any ideas on the issue?
Model DLE2701V
Thank you
Groups: Expert
I suspect that the motor relay on the board is stuck on. You could try gently tapping on it to see if it opens again. Probably going to need a new relay or a new board.
Thank you so much.
Not knowing much about electronics can you please advise which column and row the relay would be in that picture.
Also, is that control board picture a generic one or is that one specific for my model? If that is for my modl do you happen to have the part number for it?
Thank you
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have the exact issue on a DLEX2501V, can’t seem to find a circuit board
Groups: Expert
Rank: Guest
Originally Posted by: Guest  I have the exact issue on a DLEX2501V, can’t seem to find a circuit board I have the same issue, with LG dryer DLEX3850V, only a year old.
