Hello When I plug in the Freezer, I wont start, no noise at all. I replace the timer, no luck. I bought what I thought was the relay for the Embraco EM55HNR compressor but it doesnt appear its the correct one. Any ideas what to do next? Do I buy a 3 in 1 starter? I cant find any good info online or videos to troubleshoot it.
Groups: Expert
That worked I jumped the thermostat and it worked, now I looked up the part # for the thermostat and it seems they dont make it any longer but I saw some universal ones on Amazon. Could you recommend a replacement one for this, I not worried about exact fitment, I can drill a new hole for the control knob, I just want to find one that will work mechanically for this upright freezer. The model of the thermostat is a model 216303500. Thanks for your help. Photo of t stat https://photos.app.goo.gl/PblnyH9tf3XdUl0h2Will this one work? https://www.amazon.com/Durable-2...eezer+thermostat+control
Groups: Expert
The one you picked from Amazon is for a refrigerator, not a freezer. The temperature range would be too high. You need one for a freezer, low temp.
How does the little tube from the cold control attach to the coils in the freezer?
If you could get a couple of pictures of that it would help.
In the past I have used a universal thermostat like the Ranco K-401 to replace some cold controls. Its temperature range is -22 F to -2 F. Its a direct sensing type and connects to the evaporator tubing to sense the temperature of the freon.
The other type of cold control / thermostat is the air sensing kind. That's what most refrigerators have. Its mostly for temperatures above freezing.
If you go to Epay (i have to change the B here or this site will block it) and search Ranco K-401 there are some available . They have a lot of different mounting plates and many option on shaft type, to fit different knobs. It might be what you need.
