Firebc
#1 Posted : Monday, January 8, 2018 1:37:11 PM(UTC)
Firebc
My broiler will ignite and cycle off and then won't ignite again. The spark ignitor will click 3 separate times but sometimes it ignites and sometimes not. I have checked both the broil and bake valve across the common terminal and both have 210ohms. My suspicion is the DSI module and was wondering if anyone can confirm that? Thanks for any input!
#2 Posted : Monday, January 8, 2018 9:22:19 PM(UTC)
Start the troubleshooting from visual inspection of the broil burner lighting holes (near the igniter). They should be completely open. You can use a toothpick to clean them. Make sure the igniter tip is properly aligned with the lighting holes and it is clean.
Firebc
#3 Posted : Tuesday, January 9, 2018 5:54:34 AM(UTC)
Firebc
Gene,
I will double check the burner and igniter alignment but I suspect they are fine because it does in fact ignite. It just seems after cycling it doesn’t always reignite. It does click/spark but the it appears power is not sent to gas valve because it doesn’t ignite and there is no gas odor. Thanks!
Firebc
#4 Posted : Wednesday, January 10, 2018 6:13:24 AM(UTC)
Firebc
I have checked the ignitor alignment and it looks good. The burner was inspected and is clean with no blocked holes. Any idea on what else could be wrong because it’s still doing the same thing. Thanks!
#5 Posted : Wednesday, January 10, 2018 12:54:14 PM(UTC)
Check the alignment of the gas regulator to the oven burner tube as described in attached service pointer. Align if it's needed.
Firebc
#6 Posted : Wednesday, January 10, 2018 1:13:43 PM(UTC)
Firebc
I will check and advise. Thanks so much for your help!
