AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Need Quick Help!!! Found white plastic ball in drain...is this a part?
I posted yesterday about a dishwasher that wouldn't drain. got the dishwasher outside and took the pieces apart and found some popcorn kernals in the entrance to the drain. I'm assuming this is the problem, but in checking out the parts, we found a white plastic ball about 3/4" in diameter (this is a visual measurement) sitting in the part of the drain near the grinder. the ball has what looks like two small holes on each end that i think go through to each other. Is this a part and if so, where does it go back to. It appears too big to fit through drain so i'm assuming it is. We want to figure this out before we put it back together. Thanks in advance for any help.
Did you find where it went?
I have the same problem
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Dishwasher Repair
