doggydog
#1 Posted : Wednesday, January 3, 2018 3:07:27 PM(UTC)
doggydog
My ice maker is making hollow ice.The dispenser won't work because the ice all clumps together in the bin and doesn't have enough torque to break the ice apart to get it to the dispenser in the door. I'm pretty sure my RO system is providing enough water pressure as the water dispenser pumps out water plenty fast. Not using a filter because of RO system. Has anyone seen this before?
ThatGuy
#2 Posted : Thursday, January 4, 2018 2:09:31 AM(UTC)
ThatGuy
Groups: Expert
United States
usually it means the ice maker is cycling to soon. The thermostat isn't sensing the ice mold temperature right. Apparently you can't get the thermostat by itself these days. it says replace whole ice maker. Probably a good idea if it 10 plus years old.
Whirlpool D7824706Q Replacement Icemaker - AppliancePartsPros.com
doggydog
#3 Posted : Thursday, January 4, 2018 5:25:22 AM(UTC)
doggydog
Dear Thatguy,
Thank you for your response. In doing more research i started coming to the same conclusion. I appreciate your help with this.
