20 Pages«<17181920>
Hurtle
#181 Posted : Saturday, December 30, 2017 11:58:34 AM(UTC)
Hurtle
I had similar issues with a Whirlpool lgr8648pw0. No heat, but everything else ran like it was supposed to. Found the thermal fuse to be bad so I replaced it.
Put everything back together and now I don't even get power to the control panel. Fuse is good, door switch is good, outlet has power, but still no power to the unit.
Advice?
#182 Posted : Saturday, December 30, 2017 2:53:35 PM(UTC)
The thermal fuse Part number: AP6008325
protecting the dryer from overheating and has nothing to do with the control panel circuits. You may want to start the troubleshooting from verifying all wires connection, step by step.
Hurtle
#183 Posted : Saturday, December 30, 2017 6:46:00 PM(UTC)
Hurtle
Right. That's why I'm confused. Everything worked (except heat) before I replaced the fuse. Now it doesn't. I've checked conections and they all seem to be tight and attached.
Are there tech sheets for the control panel that I can use to verify connections with?
#184 Posted : Saturday, December 30, 2017 7:39:23 PM(UTC)
The tech sheet attached.
Good luck and Happy New year.
File Attachment(s):
Wiring Sheet - 3979703 - lgr8648pw0.pdf (249kb) downloaded 5 time(s).
Hurtle
#185 Posted : Sunday, December 31, 2017 9:20:47 AM(UTC)
Hurtle
Is there another failsafe or overload circuit I should be looking for?
This unit was converted from electric to LP, does that make a difference?
ThatGuy
#186 Posted : Monday, January 1, 2018 4:36:58 AM(UTC)
ThatGuy
Groups: Expert
United States
What? "converted from electric to LP" ?
Who would do such a thing?
Hurtle
#187 Posted : Monday, January 1, 2018 7:09:13 AM(UTC)
Hurtle
How often do power cords fail?
#188 Posted : Monday, January 1, 2018 9:08:56 PM(UTC)
...This unit was converted from electric to LP, does that make a difference?...
Who and how convert it? Please, describe as detailed as possible.
Hurtle
#189 Posted : Tuesday, January 2, 2018 6:00:11 AM(UTC)
Hurtle
It was converted before we got it by LP Kit#49572, so says a sticker on the inside door lip.
#190 Posted : Tuesday, January 2, 2018 1:59:48 PM(UTC)
Are you sure the dryer was originally electric? electric means the heating source was an electric heating element, powered up by 240 VAC. Also, by the model number you provided your dryer originally had a gas burner as a heating source.
20 Pages«<17181920>
