I own a side by side Whirlpool Gold refrigerator. It has an ice and water dispenser in the door. Recently the refrigerator will no longer crush the ice. It still makes ice and the water dispenser works fine, but when I select the crushed ice option nothing happens. Any ideas?
Groups: Expert
You'll need to access the auger motor. Remove ice bucket, tape emitter back, tape door switch closed. Check for either +115VDC or -115VDC (Depending on cubed/crushed) at the R/W wire and BR/W wire. Here's a diagram that might help. rickgburton attached the following image(s):
This model is from 2005. It makes ice, but the ice maker leaks water and forms icicles so I'll try replacing the ice maker. However, the part that I'm not sure about is how the ice crusher works in this model. Can anyone explain?
This is the type that has the ice bucket in the door. There's a motor and auger shaft that goes vertically up into the ice bucket. I'm thinking the motor reverses direction to make ice? There are no solonoids in this model, just a motor and shaft into the bucket. The ice crushing blades are at the base of the bucket.
The ice dispenser control board is no longer available for this model but the motor is in a few places. Can tell me how the ice crusher works on this model? Thanks!
Groups: Expert
The auger motor turns one direction for cubes and the opposite direction for crushed ice.
Thanks for the reply!! Ok, so I assume the best way to test why the crushed ice doesn’t work is to see if there’s power to the motor when I depress the lever with crushed ice selected. Looks like a 5 pin connector. I’ll see if I can figure out which is which. Since I know the regular ice dispense works I can check for voltage with that one first to narrow it down.
Would you happen to know where I can find a copy of the service manual for this model?
