jmrec100
#1 Posted : Monday, May 25, 2009 10:19:14 AM(UTC)
jmrec100
When the dishwasher starts, it sounds like the motor is trying to start. My first instinct is maybe a capacitor is bad? When I play with the cycle control, turning it past the cycle and to start again, it will start after a few tries around the dial. Anything else I should be looking for? The problem just started.
GE Dishwasher, Nautilus,
Model no: GSD3230S01WW
SN: TA832828B
#2 Posted : Monday, May 25, 2009 12:55:36 PM(UTC)
Here are the parts for a Z01WW, could not find any info on a S01WW
Replacement parts for GE GSD3230Z01WW | AppliancePartsPros.com
Since fiddling with the dial gets the unit going I would think that it is the timer causing the problem. Probably dirty contacts.
jmrec100
#3 Posted : Sunday, September 13, 2009 11:40:48 AM(UTC)
jmrec100
Can I remove the panel and clean it with contact cleaner?
#4 Posted : Sunday, September 13, 2009 2:08:42 PM(UTC)
You could try but odds of success are low due to the grease usually used on the cams.
Also hard to get the solvent to evaporate quickly so you have to leave it dry for a couple hours.
