james walley
#1 Posted : Monday, May 25, 2009 11:29:49 AM(UTC)
james walley
I Used To Vasaline To Lub The Rotating Part For The Drum, As I Had Nothing At Home.
Is The Jelly Dangerous? Now I See On The Web On Other Sites It Can Be Flammable.
james walley
#2 Posted : Monday, May 25, 2009 11:31:02 AM(UTC)
james walley
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Monday, May 25, 2009 5:19:45 PM(UTC)
Replacement parts for GE DPSR483EA1WW | AppliancePartsPros.com
Not sure what you mean by the "Rotating Part For The Drum"
If you mean the center mount drum bearing then Vaseline is probably not the best choice. You want to use a high temperature grease, wheel bearing grease will do.
Silicone lubricant oozing from under washer (Whirlpool WTW4850xQ0) (Washer Repair)
by JohnBush 11/22/2018 11:26:51 PM(UTC)
Maytag Transmission Lubricant Capacity (Washer Repair)
by naabemgr 4/18/2015 4:38:42 AM(UTC)
Lubricant leak (Washer Repair)
by vrocrider 2/5/2013 2:53:46 PM(UTC)
Dryer Drum Support rollers and lubricant? (Dryer Repair)
by Methodical 11/11/2011 7:24:24 AM(UTC)
Maytag leaking lubricant (Washer Repair)
by ddscz 5/28/2009 2:30:01 PM(UTC)
it have some lubricant? (Washer Repair)
by dennisfloress@yahoo.com 3/26/2008 7:23:10 AM(UTC)
