NDNDND
#1 Posted : Friday, October 13, 2017 5:51:14 AM(UTC)
NDNDND
Good morning!
I recently moved into my house, water dispenser worked for a little bit but then crapped out. No ice is being made. The water line is connected and on.
When I press for ice, the existing cubes will come out but are running low. When I push for water, I hear an electrical "humming" but alas, no water.
Hoping to fix this, but I am unsure where to start. Water valve is about $45, filter assembly is $35. Do I just buy both and change out both simultaneously, or should I start with one of them/with something else?
Thank you for your help!
EDIT - SORRY! Existing ice is being dispensed.
ThatGuy
#2 Posted : Friday, October 13, 2017 10:19:36 PM(UTC)
ThatGuy
Groups: Expert
United States
Since you can't get water or ice, I have to wonder if the water lines to or the filter itself is frozen up.
If it gets below 32 F or if the air is being directed right at the filter, that would do it.
