AppliancePartsPros.com
Appliance Repair Help
Trying to figure out which exact part to replace when getting Error Code "F13 ERR"
Hi, I'm trying to figure out which exact part to replace when getting Error Code F13 ERR. I've looked on the Error Code sticky where the following post, http://forum.appliancepartspros...ror-codes.html#post10830, stated "13 stands for "Bad EEPROM Identification/Checksum error". If power cycling does not help, replace the electronic oven control. You can enter your oven model number here Appliance Parts - AppliancePartsPros.com and see price and availability for the control.". However, when searching for the part there is no "electronic oven control". Does anyone know which part it is and if there is any videos showing how to replace it? Thank you.
I wanted to add some information. The "F13 ERR" only comes up when the broiler function is used. Any other time, the range works perfectly (including baking). The only way to start using the range after the error, is unplugging and plugging back in. Could the problem not be the Electronic Control Board and be something else, like the broiler element?
Thanks.
