Discuss
Oven Error Codes
 in
When your oven is flashing an error code, it usually means something specific, for example F3 usually stands for a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  6 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 07-29-2007, 12:52 PM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Cool Oven Error Codes
Brand: -brand-   Age: Less than 1 year
When your oven is flashing an error code, it usually means something specific, for example F3 usually stands for a faulty oven sensor. To help you identify what each code means, we have put together a list of oven error codes (or fault codes, as they're called). Once you know which component has failed, simply enter your appliance model number in our part search, find and order the part, and we'll take it from there. If it says that your part is in stock, you can expect to get it in just a few days, usually within 1-2 business days.
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
If you have additional questions, please click on the "POST NEW TOPIC" button on the previous page to post your question.
  #2 (permalink)
Old 09-30-2007, 10:45 AM
Sailn Sailn is offline
Junior Member
Sailn is on a distinguished road
Default Oven Codes
Thank you for the oven codes. I do not see F7-E0 under Kitchenaid.....do you have additional information??
Thank you in advance!
  #3 (permalink)
Old 10-04-2007, 06:35 PM
Administrator
APP Team
Default
Hi Sailn,
This file explains F7-E0 code in detail.
Hope this helps.
  #4 (permalink)
Old 10-20-2007, 12:20 PM
cshepherd cshepherd is offline
Junior Member
cshepherd is on a distinguished road
Default Jenn-Air w15w touchpad
I have a Jenn-Air w156w wall oven at least 10 years old. According to the information on your website, I need part AP184967, the touchpad. However, in your picture of the part the plastic electronic ribbon is two-pronged. The one on my oven is one flat strip. Will this still work?
  #5 (permalink)
Old 11-05-2007, 04:28 PM
ron speakthunder ron speakthunder is offline
Junior Member
ron speakthunder is on a distinguished road
Default Over Error Code: 5ab
While attemping to set clock back from daylight savings time the above code appeared on a Madic Chef Range and can not use oven. What has to done?
  #6 (permalink)
Old 11-13-2007, 02:40 AM
Administrator
APP Team
Default
Hi Ron,
5ab code should be explained in your use and care manual. If you post your model number here, I'll try to find the manual for you.
  #7 (permalink)
Old 11-14-2007, 01:13 PM
Administrator
APP Team
Default
Ron, press and hold the CLOCK button for about 5 seconds. That should turn off the Sabbath mode and get rid of the code.
  #8 (permalink)
Old 01-06-2008, 07:13 PM
pat.cusack pat.cusack is offline
Junior Member
pat.cusack is on a distinguished road
Default Frigidaire oven codes only go to F8
I did a google search which brought me to this site with the teaser that the error code F13 had something to do with a dispensor motor - which sounds like a washer.
My built in oven is displaying the F13 error code when we try to set the bake temperature. Cycling the power does not fix the problem. Any idea what it is and how to fix it?
Pat
  #9 (permalink)
Old 01-06-2008, 10:09 PM
Administrator
APP Team
Default
Pat,
Frigidaire has recently come out with new error codes, including F13. We'll update our code page shortly.
F13 stands for "Bad EEPROM Identification/Checksum error". If power cycling does not help, replace the electronic oven control. You can enter your oven model number here http://www.appliancepartspros.com/partsearch/ and see price and availability for the control.
Hope this helps.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #10 (permalink)
Old 01-09-2008, 07:20 AM
mark.sapienza@acco.com mark.sapienza@acco.com is offline
Junior Member
mark.sapienza@acco.com is on a distinguished road
Default
I am getting a red F2 error code as well as an E1 code at the same time on the readout. I believe this is an indication of a bad membrane touch pad. (expensive part as you know). If so, is there anything I can check to be sure? The codes come on 60 seconds after I turn the breaker back on and cannot be removed. The whole issue actually started with the door lock mechanism not working properly. Is it possible they are related?
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
