mcl143
#1 Posted : Wednesday, August 23, 2017 4:54:09 AM(UTC)
mcl143
My Maytag Bravos MVWX655DW1 will not spin much. The agitator works, but the drum won't spin much. The belt and pulleys are looking good and tight. The nuts are tight. Nothing is clogged. Nothing feels or looks out of place underneath.
The drum spins easily by hand with no sounds. There was a grinding noise yesterday when it was spinning, but nothing today.
Is there a gear or something that would allow the agitator to spin and not the drum?
brobriffin
#2 Posted : Friday, August 25, 2017 7:17:28 AM(UTC)
brobriffin
Man
United States
So you are saying that when the unit is in spin mode that the agitator spins but not the drum?
If so it may be the actuator (shifter) is not engaging the gear-case to spin the drum. This is a frequent part that fails.
Whirlpool W10913953 Actuator - AppliancePartsPros.com
It may also be a bad gear-case.
Whirlpool W11035751 Gearcase - AppliancePartsPros.com
deodatus
#3 Posted : Wednesday, September 13, 2017 11:30:29 AM(UTC)
deodatus
I have the same issue; also, a week before this started, the washer would not balance when spinning no mater how I arranged the clothes. Are these two symptoms related?
Thanks for any help.
brobriffin
#4 Posted : Wednesday, September 13, 2017 12:05:41 PM(UTC)
brobriffin
Man
United States
No your issue is bad suspension rods. To verify they are bad perform the bounce test. See video for reference.
https://youtu.be/8AvI9ma6rO4
Look up your model number on APP and find your rods.
brobriffin
#5 Posted : Wednesday, September 13, 2017 12:08:42 PM(UTC)
brobriffin
Man
United States
Sorry for short answer. Limited internet here in florida after the silly hurricane.
deodatus
#6 Posted : Wednesday, September 13, 2017 4:53:07 PM(UTC)
deodatus
Thanks for the reply! I'll get back to you when I can.
Hope all is well for you.
brobriffin
#7 Posted : Friday, September 15, 2017 2:41:23 PM(UTC)
brobriffin
Man
United States
Here is a video of how good suspension rods will act.
https://youtu.be/ILYGQ9t0v0Y
