2 Pages<12
kawfeeman
#11 Posted : Thursday, January 24, 2008 6:43:10 AM(UTC)
kawfeeman
you need to open the door at the right time to see temp rise or not ... Firstly, try Pot / pans cycle.. first of all, run your hot water for 30-60 seconds and check ultiimate temp of your hot water .. then run the d/w with a water glass on top rack , right side up , empty ( CLOSE SOAP DISPENSER ) do not add detergent.. Run d/w ( remain in the kitchen to listen for dispenser open , wait 12-14 minutes after dispenser opens and check water temp in basin of d/w and compare to water temp in the glass... then cancel program after measurements...
tmorin
#12 Posted : Friday, June 13, 2008 5:27:31 PM(UTC)
tmorin
I have a similar problem and have been following this thread. What was the solution?
Regards
tmorin
tmorin
#13 Posted : Saturday, June 14, 2008 1:49:25 PM(UTC)
tmorin
Interesting. I've ordered the 2 temp sensors. I'll replace and go from there. This thread was useful.
tmorin
pizzyfixit
#14 Posted : Sunday, May 24, 2009 3:07:50 PM(UTC)
pizzyfixit
will the timer in rinse and hold go all the way around back to the start position. My timer stopped aroung 4 o clock. The bosch shu4002 hangs up and runs forever on the regular cycle.
thks
2 Pages<12
