Outer burner works small one inop replaced burner now neither works plug old back in outer works inner doesn't ch continuity of wires to switch ok have not Ck with stove on don't know the switch voltage diagram when hot the replacement # 316555800 had to file down the gray male tab my connector female was small thank you
