large outer burner in dual burner not working at all. small burner working normaly. Had issue about 2 years ago with large burner staying on high. Installed new dual burner switch, working fine until 3 weeks ago.:confused:
Originally Posted by: bschur63  large outer burner in dual burner not working at all. small burner working normaly. Had issue about 2 years ago with large burner staying on high. Installed new dual burner switch, working fine until 3 weeks ago.:confused: Bschur, It's probably the dual burner switch, again. Part number: AP2622889
The best way to properly varify the problem is to check voltage at the switch terminal or burner terminals. Do you have a multi meter to test with ? :) :) :)
