robert44483
#1 Posted : Saturday, June 17, 2017 3:04:37 PM(UTC)
robert44483
Start wash cycle and the fill sensing light turns ... then it pauses and the lid light comes on then it starts to fill but stops and then the lid lock light starts flashing and the machine stops with the fill sensing light lite and lid lock flashing
brobriffin
#2 Posted : Sunday, June 18, 2017 5:45:08 PM(UTC)
brobriffin
Man
United States
A flashing Lid Lock light tells you there is an error that needs to be resolved.
The error could be anything from a bad lid lock, to a bad shift actuator, to a bad start run capacitor, to a bad motor. You need to put your machine in diagnostic mode and read the error codes if you feel comfortable doing so, to find out what is the matter.
Amana washer load like a flying airplane (Washer Repair)
by wilsonjiaho 4/30/2024 1:48:54 PM(UTC)
Amana washer not filling properly (Washer Repair)
by carcajou 5/12/2023 10:53:05 AM(UTC)
Amana washer makes grinding noise when running (Washer Repair)
by Bruce Congioloso 5/14/2020 11:44:16 AM(UTC)
New lid swtch on Amana washer...stuck in lock mode (Washer Repair)
by Amana2019 10/23/2019 6:27:52 PM(UTC)
Amana washer Mod. NAV5805AWW noise on spin (Washer Repair)
by miltongina 6/18/2019 2:50:00 PM(UTC)
Help with clog at bottom of Amana washer (Dishwasher Repair)
by juntjoo 1/23/2019 12:44:37 PM(UTC)
Amana washer auto sensing issue (Washer Repair)
by kennchrisl 1/21/2019 6:36:03 AM(UTC)
Amana washer shaking during spin, need help diagnosing (Washer Repair)
by Tryin2FixIt 9/21/2018 5:08:01 PM(UTC)
amana washer, grinding noise (Washer Repair)
by oilspotnm 8/11/2018 10:04:08 AM(UTC)
Amana washer spins for a second then binds (Washer Repair)
by Yaitsgotahemi 4/18/2017 3:52:52 PM(UTC)
Amana washer, replace seal ? (Washer Repair)
by djim 2/27/2016 9:34:32 AM(UTC)
Amana washer will spin, but not agitate (Washer Repair)
by giant_gnome 8/1/2015 7:31:04 PM(UTC)
Amana Washer Leaks (Washer Repair)
by axis9313 6/24/2014 3:50:30 PM(UTC)
Amana washer won't spin fast enough (Washer Repair)
by snwatts 6/16/2014 3:11:18 PM(UTC)
Amana washer error code "od" (Washer Repair)
by merresc 2/5/2014 1:46:05 PM(UTC)
