djfishe1
#1 Posted : Wednesday, June 7, 2017 6:33:23 AM(UTC)
djfishe1
My Samsung icemaker all of sudden started to flood. I turned off the water and bought a new icemaker. It was easy to install, only took a few minutes.
There is a reset button on the icemaker that needs to be pushed to start the operation. I pushed the reset and the refrigerator chimes as if it is starting to operate. However, it has been a couple of days and the icemaker still isn't making ice?
I took out the icemaker and reinstalled it. Same thing. It does send water thru the filter to the front of the door but there is no water in the icemaker? Any ideas?
:confused:
PNWDrew
#2 Posted : Saturday, June 10, 2017 7:55:59 PM(UTC)
PNWDrew
Some of these need to be reset to clear error codes. Try unplugging the unit for a few minutes and see if it improves.
Just FYI-The button on the icemaker isn't a reset it's a test cycle.Push it and shut the door or trigger the magnetic door switch with a decent magnet up near the hinge. You'll know when you've found the reed switch when the lights go off. The ice bin may need to be in also.
You should hear the IM cycle, ending with a fill. If it has water in it it will overflow, or dump that water as it cycles.
Are you certain the IM overflowed? Did you directly see the issue? These are known for clogged defrost drain tubes, accumulating water/ice under drawers, or on bottom of freezer. This impairs it's cooling and the IM will not cycle if not cold enough.
Or the air duct blowing up from freezer is iced over and the ice room isn't cold enough.
Welcome to the murky world of Samsung... Sometimes I spend an hour just identifying the problem.
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
ICEMAKER ISSUE: Kitchenaid KSRS27QFAL00 Superba (Refrigerator & Freezer Repair)
by jselko 10/14/2023 1:30:11 PM(UTC)
Icemaker for Kenmore 106.51764510 (Forum Announcements)
by jzannini 9/26/2023 12:37:24 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
GE Undercabint Icemaker (Refrigerator & Freezer Repair)
by rjcunning 4/9/2023 7:35:53 AM(UTC)
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
New icemaker failed (Refrigerator & Freezer Repair)
by 7Pat 12/18/2022 11:40:20 AM(UTC)
Buy (200 Pcs) New Insignia - 44 Lb. Portable Nugget Icemaker $39,800 (General Talk)
by eikohajime30 11/9/2022 10:16:55 PM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
