flame comes on only for a few seconds then goes off, everything else seems to be working properly
Ordered them, we'll see soon enough thanks
When you change them look for a small metal sleeve on the 3 wire coil.. It often comes off with the coil but should be switched over to new one if present.
Other than that its just a few wires and a few screws.
Good luck!
will do, thanks again, Mike
