domspii
#1 Posted : Tuesday, May 23, 2017 6:18:46 AM(UTC)
domspii
Hi, have a Whirlpool front loader and it stops working during the wash cycle. If I press play once it stops it makes a constant noise but nothing is happening. The light blinks 8 times.
I hope this helps! Please help!
domspii
#2 Posted : Tuesday, May 23, 2017 6:21:07 AM(UTC)
domspii
I forgot to mention that once it is making that constant noise the only way to stop it is to hold the power button for approximately 15 seconds so the machine shuts down completely.
brobriffin
#3 Posted : Tuesday, May 23, 2017 6:28:30 AM(UTC)
brobriffin
Man
United States
Questions
At what point during the wash cycle does it stop?
1. after it has filled before it starts to agitate.
2. after it has agitated for a while.
Does the drum spin or agitate at all?
What light blinks 8 times?
Have you tried drain and spin cycle, if so what happens then?
domspii
#4 Posted : Tuesday, May 23, 2017 6:49:59 AM(UTC)
domspii
Hi brobriffin, thank you for replying.
It stops approximately 3-4 minutes into the wash cycle. During that 3-4 minutes all it does is spin left, then right.
The Wash light blinks 8 times.
brobriffin
#5 Posted : Tuesday, May 23, 2017 7:19:36 AM(UTC)
brobriffin
Man
United States
Does the wash light pause then blink 8 times again or does it pause and blink once
domspii
#6 Posted : Tuesday, May 23, 2017 7:22:21 AM(UTC)
domspii
The wash light pauses. then blink 8 times
brobriffin
#7 Posted : Tuesday, May 23, 2017 7:29:02 AM(UTC)
brobriffin
Man
United States
The F8 fault leads us to a water system. Some times the F8 is followed by either one or more blinks giving a definite why.
It may be a problem with long fill or over filling.
Does your machine completely drain all of the water out?
What is the sound you hear? [constant noise] Is it coming from the bottom of the machine?
domspii
#8 Posted : Tuesday, May 23, 2017 7:38:17 AM(UTC)
domspii
I took a video of the noice it is making
https://www.youtube.com/watch?v=aznPu_hHQxY
brobriffin
#9 Posted : Tuesday, May 23, 2017 7:44:18 AM(UTC)
brobriffin
Man
United States
Ok thats normal.
The sound you are hearing is the drain pump. It will run for approx 10 minutes.
Let that complete and try washing again.
Also I noticed the flashing codes it seems in the brief video that there was a single flash after the 8. If that is true it indicates long fill. You may have an obstruction in the inlet valves or the filter screens or the inlet valves may not be fully opening.
Guest (4)
Whirlpool stops after wash cycle will not drain or spin (Washer Repair)
by JF2015 1/4/2015 7:19:52 AM(UTC)
Whirlpool Stops ramdomly during cycle (Washer Repair)
by bulletbkr 5/2/2011 8:10:46 AM(UTC)
Whirlpool stops cooling until temp cycled off-on (Refrigerator & Freezer Repair)
by jhillman1 1/20/2011 8:39:33 AM(UTC)
Whirlpool stops when time to pump out water (Washer Repair)
by davecjr 3/26/2009 6:18:55 AM(UTC)
