maj127
#1 Posted : Wednesday, May 3, 2017 12:29:55 PM(UTC)
maj127
The metal lint clip in the lint mechanism is bent out of place. I have no idea what it is supposed to look like to fix it!! Please Help.
I have a matag Bravos XL
Thanks!
PNWDrew
#2 Posted : Wednesday, May 3, 2017 7:01:33 PM(UTC)
PNWDrew
If you mean the flat piece down inside that pushes the filter against the rear wall of the duct you'll probably need to pull the front off to get to it unless you have very small hands. That's not a hard one to pull apart..
It should be shaped like #28 on this diagram. Often grabs the filter and bends out of shape.
Parts for Maytag MEDB700VQ0: Bulkhead Parts, Optional Parts (not Included) Parts - AppliancePartsPros.com
1st it isn't a major issue, so use the machine if needed while you sort it out. any lint that misses the filter will exit through the blower, no immediate risk.
If you wish to pull the front off and repair/replace post back and I or someone will help. I can't find a pic of it in it's proper shape.
Guest (4)
