Alphadog
#1 Posted : Saturday, May 23, 2009 2:15:11 PM(UTC)
Alphadog
Hi all! I have a Kenmore Series 80 washer that has decided to stop spinning. Everything else works great, in fact if I open the lid and spin it by hand it gets the momentum to keep going and will speed up and finish the cycle. What do I need to do to fix this? Thanks
#2 Posted : Saturday, May 23, 2009 5:37:08 PM(UTC)
The first thing I would do is check the drive block (#15 on the diagram). If there is nothing wrong then the problem most likely is a bad clutch (#5 on the diagram)
You can find the instructions in one of our previous posts: http://forum.appliancepartspros...ir/373-not-spinning.html
Perform the troubleshooting and post the results.
