When going to bake the display shows F3 flashing. The contrpl board is a Robershaw pn100-275-03. What does F3 stand for? The sensor measurs 1028 ohms on a digital meter.
The "F3" error code means the control board senses an open oven temperature sensor. The oven sensor resistance suppose to be about 1100 Ohms at the room temperature (about 75 degrees). The reading of 1028 Ohms is too low. Most likely the oven sensor has to be replaced. - The part number for the oven temperature sensor is AP3130719 Good luck. Gene.
