19 Pages«<1516171819>
gteasley
#161 Posted : Thursday, April 21, 2016 8:49:18 AM(UTC)
gteasley
Does anyone know about a bosh model # shx46a It will not drain. Can I test for this before ordering parts
bcollinge
#162 Posted : Friday, March 24, 2017 8:47:56 AM(UTC)
bcollinge
This is great, thanks!
jamesgluten
#163 Posted : Monday, April 10, 2017 9:51:20 PM(UTC)
jamesgluten
Hey, i see you are facing a lot of problem due to your dishwasher..Well i have the solution to your problem i found this link on internet..really a helping article Bosch Dishwasher Error Codes: E15, E22, E01, E09 | Error Codes Pro . You can find your solution here.
kli
#164 Posted : Tuesday, April 11, 2017 10:09:04 PM(UTC)
kli
Originally Posted by: jeremydfaust Go to Quoted Post
Hi, Thanks for the info. My 2006 SHE45 had the heater prong burnt out in the control module as did most of the models in this thread. I'd like to report that all is working great with the rather quick and painless repair.
Thanks again.
Burnt in Buffalo
I'm having a similar issue with my she45m05uc/50. Based on the symptoms (abnormally long runs, lukewarm wash etc) it seems like it could be a burnt out solder joint connection. Unfortunately I got as far as the control panel cover. I was able to partially open it, but the design is different than what is mentioned in this thread and in the guide i followed below. One side of it doesn't even appear to be able to open despite the back being hinged. I'm afraid of using any more force than I already have for fear of breaking the cover.
Through the portion i was able to open, i was able to view most of the board. As far as I could tell, I couldn't see any damaged connections. However, I can't be 100% certain. Does anyone have any advice on how to open my particular model's cover? Or thoughts on possible other causes of what is happening?
Thanks,
Kelvin
Oh, also the Error Code I get when hitting the 2 mode buttons + Power is: C6
I haven't come across what that means.
Bosch SHU43 Dishwasher Repair - Dishwasher keeps running (Stuff)
#165 Posted : Wednesday, April 12, 2017 7:57:27 PM(UTC)
Very likely you would need to remove the outer door panel fist. Try to follow the instructions from attached file.
File Attachment(s):
How to replace control module.doc (130kb) downloaded 62 time(s).
kli
#166 Posted : Thursday, April 13, 2017 8:16:15 AM(UTC)
kli
Hi Gene -
Thanks for the reply!
I actually did remove the outer door panel as well as separating the fascia console from the frame. However I there were no tabs as far as I could tell that would allow me to separate the control module from the frame. And I was unable to open the control module cover completely, as one side of it didn't even appear to have an opening all the way around.
I will try to post some pictures when I get home tonight.
Any thoughts on what the code C6 means?
kli
#167 Posted : Monday, April 24, 2017 2:09:33 PM(UTC)
kli
Here are the pics of my washer's control module cover. I can't figure out how to get it open, as mentioned:
Originally Posted by: kli Go to Quoted Post
Hi Gene -
kli attached the following image(s):
#168 Posted : Monday, April 24, 2017 3:25:05 PM(UTC)
How does it look from the other side of the metal panel?
kli
#169 Posted : Thursday, April 27, 2017 7:39:21 AM(UTC)
kli
Here are the pics
kli
#170 Posted : Thursday, April 27, 2017 7:40:53 AM(UTC)
kli
Hm... after staring at the pics now, I just noticed that maybe i can push the tabs in from the left side to release it thru the opening?
Here are the pics
