Hoglover
#1 Posted : Friday, April 7, 2017 2:37:33 PM(UTC)
Hoglover
Door switch was bad replaced switch was replaced dryer still wont run when I bypass switch dryer works what is going on
ThatGuy
#2 Posted : Friday, April 7, 2017 3:09:36 PM(UTC)
ThatGuy
Groups: Expert
Have you tried starting the dryer with the door open?
Perhaps you have the wires switched.
Are you using this part?
Frigidaire 134813601 Switch - AppliancePartsPros.com
Hoglover
#3 Posted : Friday, April 7, 2017 3:48:26 PM(UTC)
Hoglover
Thought I had crossed the wires also so I switched them and still no go runs great when I tie the wires together and it does it hot it has one of those computer type boards could that be a problem?
ThatGuy
#4 Posted : Friday, April 7, 2017 6:15:12 PM(UTC)
ThatGuy
Groups: Expert
How many wires go to the switch?
If you have a light inside there should be three. One is common, one goes to the light (NC), and one goes to the motor(NO).
Do you have a wiring diagram?
https://www.youtube.com/watch?v=vs3npVPY76g
UserPostedImage
Hoglover
#5 Posted : Friday, April 7, 2017 7:03:40 PM(UTC)
Hoglover
No light works at a loss
Hoglover
#6 Posted : Friday, April 7, 2017 7:03:41 PM(UTC)
Hoglover
ThatGuy
#7 Posted : Friday, April 7, 2017 11:02:28 PM(UTC)
ThatGuy
Groups: Expert
I know I'm really tired, but what does this even mean? Its not even a real sentence.
You say your dryer starts if you short the wires together.
That leaves three possibilities.
(A) the switch is bad.
(B) The wires are on the wrong terminals of the switch.
(C) The switch is not being depressed for some reason.
I'm done. No more.
Maytag MVWC4658W2 Door switch? Will drain but not spin. (Washer Repair)
by JimAlbr 6/4/2020 5:49:53 PM(UTC)
Dryer keeps blowing the DOOR SWITCH?!?! (Dryer Repair)
by ppipowerclass 12/3/2017 12:54:14 PM(UTC)
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
door switch (Dryer Repair)
by Cole B. 8/28/2016 10:26:07 AM(UTC)
How to remove the door switch (part #AP4442085) (Refrigerator & Freezer Repair)
by rannug 4/20/2016 10:12:10 AM(UTC)
wiring for maytag door switch (Dryer Repair)
by macjane94 5/29/2015 10:25:15 AM(UTC)
Door switches not operating properly (Microwave Repair)
by restlesssailor 4/19/2015 12:21:54 PM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
How do I disconnect door switch? (Dryer Repair)
by ocampon 12/12/2014 3:18:51 PM(UTC)
Can't put the freezer door switch back! (Refrigerator & Freezer Repair)
by bzk 5/13/2014 5:22:07 PM(UTC)
Door switch (Dryer Repair)
by cecildow 2/18/2014 7:30:35 AM(UTC)
intermittant dryer door switch (Dryer Repair)
by Jstanh 12/22/2013 4:43:59 PM(UTC)
Cannot find door switch on this unit.. (Washer Repair)
by goosehunter10876 11/18/2013 11:44:33 AM(UTC)
Door switch replacement (Microwave Repair)
by pilotlite 10/1/2013 7:55:01 AM(UTC)
Old Door Switch wiring (Washer Repair)
by nkornelis 9/5/2013 12:41:45 AM(UTC)
