mga4mba
#1 Posted : Sunday, April 24, 2011 3:02:23 PM(UTC)
mga4mba
Advantium in-wall oven stopped working in the middle of advantium cooking. There is no display in the LED panel - cooking stopped. Checked the breaker, power is OK. Read similiar repair posts, and pulled out the oven and found the wiring schematics. Tested the fuse - OK. Tested all leads in the control panel - all OK. Any thoughts on what else to check, before calling in a service repairman?
TxDan
#2 Posted : Sunday, March 19, 2017 5:11:32 PM(UTC)
TxDan
Did you test the three Thermal cut off switches? One on the Magnatron and two on left side above and on side. Simple Continuity checks!
Dan
