Advantium in-wall oven stopped working in the middle of advantium cooking. There is no display in the LED panel - cooking stopped. Checked the breaker, power is OK. Read similiar repair posts, and pulled out the oven and found the wiring schematics. Tested the fuse - OK. Tested all leads in the control panel - all OK. Any thoughts on what else to check, before calling in a service repairman?
Did you test the three Thermal cut off switches? One on the Magnatron and two on left side above and on side. Simple Continuity checks!
Dan
