Lankye31
#1 Posted : Friday, March 10, 2017 6:13:26 PM(UTC)
Lankye31
I have a maytag centennial dryer that will heat up but not spin. I have checked the belt and that is not the problem, and I have tested the door switch. Other than the motor is there something else that could cause the problem?
Thanks for the help!
ThatGuy
#2 Posted : Friday, March 10, 2017 10:39:20 PM(UTC)
ThatGuy
Groups: Expert
United States
If it is heating and the motor is not running, then the motor's start switch must be stuck in the "run" position.
https://www.youtube.com/watch?v=6wnEEIAsmok
Yours would be the opposite problem. Your contacts would be welded together or the switch is stuck on.
Does the motor hum or do anything?
Lankye31
#3 Posted : Saturday, March 11, 2017 6:05:48 AM(UTC)
Lankye31
No, my motor makes no noise at all and doesn't make an effort to run.
Thanks for the reply!
Lankye31
#4 Posted : Saturday, March 11, 2017 6:29:01 AM(UTC)
Lankye31
