handyman68
#1 Posted : Saturday, May 23, 2009 10:00:30 AM(UTC)
handyman68
washer fills - washs - drains - don't spin
any help would be appreciated
tdma
#2 Posted : Saturday, May 23, 2009 5:08:38 PM(UTC)
tdma
I had the same issue with mine.
It was the motor coupler, seems to be a common failure. The replacement part is reenforced with a steel sleave to prevent it from happeing again.
It is a lot of work to change but worth it as the part is less than 20 bucks.
Replacement parts for WHIRLPOOL LSR7233DQ0 | AppliancePartsPros.com
AP3963893
I don't have the service manual, but it would be helpfull to show you how to remove the tub to get to the motor.
Guest (4)
