Hello had this fridge for about 6 years and I'm running into a issue where the Auger Motor keeps spinning when i shut the freezer door. I removed the motor for the time being. i took apart the ice/water dispenser on the door, hoping it was the circuit board. but, i disconnected all the wires that were plugged in the board turned the fridge back on and it was still spinning. Any other suggestions?
thanks!!!
Did you get this figured out? I did the exact same thing, took the circuit board out of the front and it still kept spinning? Any updates would be helpful!
Thanks!
Hey there....
I ended up replacing the control board and that did the trick. Here's what I bought off ******** for 95 bucks.
2322547 WHIRLPOOL KENMORE REFRIGERATOR CONTROL BOARD OEM NEW
Good luck
Just wanted to say thanks for replying and giving me that info. I replaced the same part you did and now mine works perfect!
Thank you kind sir!
