Jlb86
#1 Posted : 8 years ago
Jlb86
My Kenmore dryer timer will not advance and will not shut off unless I open the door. I'm wandering if I can fix it or if I just need a new dryer.
ThatGuy
#2 Posted : 8 years ago
ThatGuy
Groups: Expert
United States
Your description is a little vague.
The timer will not advance in any of the cycles? Even timed dry?
Does it seem to be heating OK?
When it reaches the end of a cycle (lets say you turn the knob manually) It won't shut off and the only way to stop it is to open the door?
Jlb86
#3 Posted : 8 years ago
Jlb86
No the timer will notadvance on any setting. It dries just fine. But will not shut off unless the door is opened
ThatGuy
#4 Posted : 8 years ago
ThatGuy
Groups: Expert
United States
In that case its most likely the timer. Probably has a contact welded together inside.
Jlb86
#5 Posted : 8 years ago
Jlb86
Where would I find a new part? Its an '80s model
ThatGuy
#6 Posted : 8 years ago
ThatGuy
Groups: Expert
United States
Can you post your model number?
thorning
#7 Posted : 8 years ago
thorning
You need to put in the model number to help identify the p/n of the timer. You can usually find it on this web site Appliance Parts Pros or an alternate location is ApplianceJunk.com . Dont be suprised if you find the cost is more than $100 in which case you should consider getting a new dryer.
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 10 years ago
Dryer timer will not advance (Dryer Repair)
by Brian7780 15 years ago
Dryer Timer Will Not Advance (Dryer Repair)
by cyclone 16 years ago
Dryer Timer will not advance in Automatic (Dryer Repair)
by kabgreen 17 years ago
