I know this subject has been discussed before, however is there a solution for an oven, approx two years old where the hinges have been replaced twice and the door has never stayed closed?:mad:
I am about to purchase my third set of hinges and the plan is to somehow make the springs stronger before putting them in.
Can anyone offer an alternative to fix this problem?
Thanks for the reply. I would like the correct part number for the repair kit. The serial number is 20877861GX.
Thanks Gene. Will purchase the hinge and receptacles. I guess I have to pull the oven out to replace the receptacles
I'm having issues with door not making tight seal.....found this old thread but the link to the Maytag Technical Bulletind is no longer valid. Does anyone still have or know how to get correct part no for the hinges for
Model: JMW9530DAS Serial: 22537114JL
Thanks, Mark
