AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Samsung Top Load Washer starts to fill then stops, code nF
Hello, Hoping someone here has some advice for me. Recently my Samsung top load washer stopped filling during most of the wash cycles. Here is what happens: [LIST=1] Power on Fill washer with clothes/detergent Close lid Select wash (Normal is most frequently used) Washer drains tub of leftover water Washer starts to fill/spin tub at same time About 45 seconds later washer stops filling (tub still spins) ~6 minutes later the nF code is thrown because water level hasn't changed[/LIST]Here are the things I have done so far:
- Pull/clean/replace the intake screens (no issues)
- Run through the quick tests - all seems good i think?
- Replaced the water level sensor with one from APP.com (just the sensor, not the hose itself due to time restraints)
Nothing I have done has changed anything. The washer still starts to fill and then stops. I don't think its the lid switch and here is why, if I set it to rinse/spin it will fill the entire tub (almost overfill) and it will run the entire cycle. I don't think it would run if the lid switch was bad, could be wrong?
Any help is greatly appreciated. Thanks!
Bumping this, anyone have any ideas?
Washer Repair
