2 Pages12>
mvm150
#1 Posted : Monday, January 30, 2017 2:34:36 PM(UTC)
mvm150
My washer makes a loud noise when it goes into spin cycle; but it doesn't spin unless I lift the lid until it quits making the the noise and then when I shut the lid it starts spinning and sounds normal. I replaced the transmission because it was leaking oil on the floor and I thought it might be what was causing the problem. The noise was still there after replacing the trans so I replaced the basket drive assembly, the washer drive block and and the brake and drum assembly along with both coupler assemblies and it still does the same thing. It sounds like the transmission is whining trying to get into gear but it's new?
ThatGuy
#2 Posted : Monday, January 30, 2017 3:11:20 PM(UTC)
ThatGuy
Groups: Expert
United States
Just a quick question, what is the temperature in the room where the washer is?
mvm150
#3 Posted : Monday, January 30, 2017 4:54:46 PM(UTC)
mvm150
around 70 degrees
PNWDrew
#4 Posted : Saturday, February 4, 2017 10:52:01 AM(UTC)
PNWDrew
Sounds like it's in neutral drain, a normal stage of the cycle. All Whirlpool direct drive transmissions have a neutral drain stage, however many older transmissions do not do it well or have stopped doing it.
1)The timer ends agitation and reverses the motor.
2)It pumps out but trans remains in nuetral. There is a distinct noise to this stage. To many it sounds like it's straining.
3)After a few minutes (it may vary by cycle) the timer briefly removes power from the motor, this switches trans into spin.
4)The timer reapplies power and it spins.
By opening the lid you are simulating #3, so when you close the lid the trans will spin. Allow it to proceed without opening the lid while making this sound, if it is pumping out normally and switches into spin on its own you're fine.
About neutral drain. It tended to fail as the trans aged and you may not have been hearing it before with the old trans. When neutral drain fails the trans flips into spin at the end of agitation or very shortly afterward and the machines spin and drain together. This put more stress on everything so there is the neutral drain stage to allow the water to pump out prior to spin.
mvm150
#5 Posted : Saturday, February 4, 2017 3:00:59 PM(UTC)
mvm150
I just replaced the transmission in the washer 2 weeks ago. the noise I hear sounds like the the transmission.
mvm150
#6 Posted : Saturday, February 4, 2017 3:07:14 PM(UTC)
mvm150
A few years ago the washer started making the same noise and I replaced the transmission and it fixed the problem. This time I replaced the the trans and it sounds just like the old one I took out.
PNWDrew
#7 Posted : Saturday, February 4, 2017 3:37:45 PM(UTC)
PNWDrew
You'd have to record the noise somehow then for farther analysis. These are very simple machines and I've fixed several thousand over the years, I'd probably recognize it. Perhaps take a video with your cell phone?
Can you make it make the noise by starting it at any one point in the cycle?
mvm150
#8 Posted : Sunday, February 5, 2017 12:21:35 PM(UTC)
mvm150
https://youtu.be/vjNc6iRUegM
this is the noise that it makes
mvm150
#9 Posted : Sunday, February 5, 2017 12:21:35 PM(UTC)
mvm150
PNWDrew
#10 Posted : Monday, February 6, 2017 10:15:19 AM(UTC)
PNWDrew
That's the neutral drain period, it should not spin immediately after agitation. There is a 1-3 minute period called neutral drain. If you still have the tech sheet that was under the console and look at the timer cam sequence you can see this period, after which the timer opens the motor circuit briefly then closes it, and that will send it into spin.
If you let it go another few minutes without opening the lid does it briefly stop, then go into spin? If not your timer may be bad if it isn't opening the circuit or the trans if it gets stuck in ND.
https://www.youtube.com/watch?v=GCLWPoEYesI
jump to 28:15 or 41:45 and let it play.
Note: This demo video has the lid switch bypassed so the machine believes the lid is closed. Most techs have a old lid switch plug wired to allow this, or you can hold the lid switch itself down with a pencil or something that fits through the hole and achieve same results.
Here's a look at the inside of the trans showing the neutral drain assembly.
https://www.youtube.com/watch?v=ieZ5y47TAMk.Skip to 2:10.
And finally here's a link to an explanation of the process by another site
https://appliantology.or...ore-direct-drive-washer/
Metallic noise in washer (Washer Repair)
by TRDCLNR95 4/6/2013 8:01:27 PM(UTC)
2 Pages12>
