RGH0625
#1 Posted : Tuesday, January 10, 2017 1:17:12 AM(UTC)
RGH0625
Hello,
When I use the microwave, close the door and all looks good. Push start, the light comes on and it makes the makes normal sound. The turntable does not turn and there is no heat? If I push up on the door, it works just fine. Any assistance would be greatly appreciated
Respectfully,
Rob
USN Ret.
ThatGuy
#2 Posted : Tuesday, January 10, 2017 3:37:00 AM(UTC)
ThatGuy
Groups: Expert
United States
Hey Rob,
Probably one of the door switches is failing. Once you can see them it will be pretty obvious which one it is.
The switch that doesn't have a nice click sound or the little plunger doesn't spring out right.
This is the page that shows the switches. You can probably find generic switches that would work, but here are the OEM ones. This is the model number I used to look these up. MH6141XKB1
http://www.appliancepartspros.c...hirlpool-mh6141xkb1.html
Whirlpool 4392027 Door Interlock Switch Kit (2-Pack) - AppliancePartsPros.com
