The ovens do not work. The burners do work. It seems that nothing at the touchpad works (110 volts) while the burners (220 volts) do work.
Groups: Expert
Thank you for your advise to check the thermal sensor but since the clock, timer, oven light switch, etc. doesn't work do you think it could be a bad control panel instead? Is there a way for me to check the control panel? I hate getting into a trial and error purchase method or repairing. Thanks, Jim
Groups: Expert
