jnevill1
#1 Posted : Sunday, January 1, 2017 7:20:12 AM(UTC)
jnevill1
The ovens do not work. The burners do work.
It seems that nothing at the touchpad works (110 volts) while the burners (220 volts) do work.
ThatGuy
#2 Posted : Sunday, January 1, 2017 10:50:28 AM(UTC)
ThatGuy
Groups: Expert
United States
Pretty much everything, bake, broil elements etc. lead back to the electronic control board. There is a Hi-Limit Thermostat that might have blown. I'd check it first.
Whirlpool 74009969 Hi-Limit Thermostat - AppliancePartsPros.com
Wiring diagram
Parts for Maytag MER6875AAS: Wiring Information (stl) Parts - AppliancePartsPros.com
jnevill1
#3 Posted : Monday, January 2, 2017 4:54:12 PM(UTC)
jnevill1
Thank you for your advise to check the thermal sensor but since the clock, timer, oven light switch, etc. doesn't work do you think it could be a bad control panel instead? Is there a way for me to check the control panel? I hate getting into a trial and error purchase method or repairing.
Thanks, Jim
ThatGuy
#4 Posted : Wednesday, January 4, 2017 2:26:40 PM(UTC)
ThatGuy
Groups: Expert
United States
Your control board is $326.
Whirlpool WP5701M799-60 Controlsw - AppliancePartsPros.com
I wasn't suggesting swapping parts. I thought maybe you were going to do some trouble shooting. If you are, I would test this part.......
for continuity. If its "open" Then temporally jumper it and see if the control panel comes on. If you feel uncomfortable doing any of this, you should hire it done.
Guest (4)
