orionengnr
#1 Posted : Friday, December 30, 2016 9:31:49 AM(UTC)
orionengnr
Did several searches, can't find anyone else with the same problem.
Water/ice dispenser works correctly, I can select cubed/crushed, etc.
(This is for the external water/ice dispenser and control panel)
The light for the dispenser works, but the backlighting for the buttons does not.
I have the panel off, and i'm not sure there is actually lighting inside the push-button panel. The little red "flags" pop into place to show the selection.
I have the wiring diagram, and the only light I am seeing is the one controlled by the pushbutton switch, and that works correctly.
Wife says it "used to" light up, and I'm taking her word for it...all I can say for sure is that there are a lot of wires there.
Thanks for any help you can offer.
Best, Rich
dno36
#2 Posted : Thursday, February 23, 2017 10:24:44 AM(UTC)
dno36
Hi Rich, My Fathers unit had the same issue. It was an LED attached directly to the control panel and the LED can possibly be fixed by someone who can solder well or you need a new board, which is what we needed to do at a cost of about $80.
GL
Dean
orionengnr
#3 Posted : Thursday, February 23, 2017 6:08:58 PM(UTC)
orionengnr
Thank you, Dean, for the reply.
Can you provide a part number for the board, or perhaps some guidance in disassembling whichever parts will give me access to the LED?
I can solder half way decently, and would be tempted to give it a try.
Really don't want to break something and make it worse, though...
Best regards, Rich
ThatGuy
#4 Posted : Friday, February 24, 2017 2:06:51 AM(UTC)
ThatGuy
Groups: Expert
United States
I think you got it right.
I have a WP S by S and it never had lights just those bright red pop up indicators. Your part looks just like mine which looks like this one.......
Whirlpool 2198621 Switch Assembly (also Order Item NO.19) - AppliancePartsPros.com
dno36
#5 Posted : Friday, February 24, 2017 2:28:05 PM(UTC)
dno36
Hi Rich, I will check, but I think they may have a different model. I would lean towards ThatGuy's response. GL
Guest (5)
