Bob Watts
#1 Posted : Friday, May 22, 2009 5:10:36 PM(UTC)
Bob Watts
I am attempting to replace the door lock assembly on my Kenmore front loader washer. Do I have to totally remove the rubber boot(seal) or can I just pull back the side where the lock is to reach in to grab the door lock switch. I don't want to damage the seal.
Bob Watts
#2 Posted : Friday, May 22, 2009 6:07:14 PM(UTC)
Bob Watts
Never mind.:D Just realized that I could remove the 2 screws that fasten the front door panel and pull the panel just far enough away to access the door lock assembly.
Chuck Penton
#3 Posted : Tuesday, November 9, 2010 4:13:40 PM(UTC)
Chuck Penton
The door will not lock so it can go into the spin cyc.
I found the wax motor was not working I got a new one and it stil does not work.
In metering the wires with out being connected to the wax motor I get 120 vac. With the new motor pluged in but not installed and metering I get 18.6 volts.
What do I do next
Thank you,
Chuck
Guest (5)
