Royglen
#1 Posted : Friday, December 9, 2016 7:14:19 AM(UTC)
Royglen
After replacing water filter with new one have no water to ice maker or door water dispenser. If I remove water filter everything works fine. Tried 2 different water filters, no luck. Suspect maybe the water filter housing, what's your opinion? If so can you provide me with a video or step by step procedure on how to replace filter housing. Also what model filter housing do I need to purchase from you guys. Thanks Roy.
ThatGuy
#2 Posted : Friday, December 9, 2016 9:22:17 AM(UTC)
ThatGuy
Groups: Expert
United States
Royglen
#3 Posted : Friday, December 9, 2016 9:50:32 AM(UTC)
Royglen
Filter is in all the way. Can you help me giving step by step procedure on replacing filter housing WPW10121140 or video.
ThatGuy
#4 Posted : Friday, December 9, 2016 10:11:38 AM(UTC)
ThatGuy
Groups: Expert
United States
Royglen
#5 Posted : Friday, December 9, 2016 10:30:59 AM(UTC)
Royglen
I watched that video but my filter housing WPW10121140 mounting screws are with filter housing mounted behind steel frig bracket. Looks like you may have to change it from underneath. If so all fox would have to be removed. Is this the way you see it.
Royglen
#6 Posted : Friday, December 9, 2016 10:33:18 AM(UTC)
Royglen
I watched that video but my filter housing WPW10121140 mounting screws are with filter housing mounted behind steel frig bracket instead of outside of steel bracket. Looks like you may have to change it from underneath. If so all food would have to be removed. Is this the way you see it.
Golferman
#7 Posted : Thursday, June 1, 2017 7:45:05 AM(UTC)
Golferman
I am having a water conditioning system installed for the whole house today. Do I need the water filter for my Whirlpool Side by Side Refrigerator ice maker to work. Model# WR3325FDAB01
Thermador SxS water filter housing leaking (Refrigerator & Freezer Repair)
by metropical 7/10/2021 5:43:19 AM(UTC)
Repair Water Filter Housing (Refrigerator & Freezer Repair)
by brdeckard 11/26/2019 7:29:52 PM(UTC)
Fridge Water Filter Housing Leaking (Refrigerator & Freezer Repair)
by danshaw 9/24/2017 3:20:39 PM(UTC)
Removing Water Filter Housing (Refrigerator & Freezer Repair)
by rvtbvt 7/22/2014 5:34:03 PM(UTC)
Replaced Water Filter Housing Now With Leak Under Fridge (Refrigerator & Freezer Repair)
by jikwee 10/18/2011 7:22:10 AM(UTC)
by jikwee 10/16/2011 7:25:20 AM(UTC)
removing front control panel assembly to take out broken water filter housing (Refrigerator & Freezer Repair)
by enyart 8/3/2011 11:25:53 AM(UTC)
replace water filter housing on whirlpool refrigerator (Refrigerator & Freezer Repair)
Belarus elizabethg 3/17/2011 12:04:14 PM(UTC)
replacing frigidaire water filter housing (Refrigerator & Freezer Repair)
by tontomeme 6/28/2010 6:46:14 AM(UTC)
Kenmore Elite fridge - leaking from water filter housing (Refrigerator & Freezer Repair)
by burgerman 1/23/2010 3:54:56 PM(UTC)
Gene! Kenmore Coldspot water filter housing leaking (Refrigerator & Freezer Repair)
by nails1 7/26/2009 9:25:06 AM(UTC)
water filter housing cracked (Refrigerator & Freezer Repair)
by dcg0421 6/24/2008 3:40:16 PM(UTC)
